what is difference between XG and DB mode of DFT tool
quan228228
Full Member level 4
Full Member level 4
The DFT tool of synopsys has two mode, XG and DB mode.
what is the difference?
Thanks!
David
there is no much diffrence in terms of results but in terms of the time for the compilation there is huge diffrence.XG mode will take very less time compared to the DB mode.
regards,
ramesh.s
    quan228228
Thanks:D
Added after 1 minutes:
Could you tell me more detailed infor. e.g. what is XG mode, what is DB mode?
Thank you very much!
David
Hi David,
If u want any other information related to the DB mode u can search in the solvnet there synopsys explained u much what are the diffrent advanges u will get from DB mode and what are the chages in the DB mode.
regrads,
ramesh.s
XG is the new mode that handles memory and design differently and is generally faster than DB mode.
Many commands, especially the DFT command also have different syntax, so the migration is not totally straight forwards. Thankfully SNPS gives a tool that translates scripts from one mode to the other.
I suggest you write anything new in the XG mode as after the current release the DB mode will become obsolete and unsupported
    quan228228
