In what output state does TTL circuit sink current from load
mohsin_kiet
Junior Member level 3
TTL circuit
In what output state does a TTL circuit sink current from a load
Re: TTL circuit
Current can only be sunk to a LOW ..
Regards,
IanP
    mohsin_kiet
Re: TTL circuit
As the name suggests, current sink must enable a path for the current to ground.
Hence logic LOW..
    mohsin_kiet
TTL circuit
LOw or logic "zero" state
    mohsin_kiet
TTL circuit
means logic zero.
    mohsin_kiet
TTL circuit
Hence logic LOW..
means logic zero
    mohsin_kiet
Re: TTL circuit
as you say "CURRENT SINKING..!!"
means sinking of current or simply providing a path to the current from the load to ground...
so the the logic level of the ic must be low or GND
    mohsin_kiet
Re: TTL circuit
Hi Dear mohsin_kiet!
I know one condition. If a load is not grounded and it is connected to VCC, the TTL will draw current from it. An application of such configuration would be the connection of a load to an open collector TTL package.
Thanks!
    mohsin_kiet
Re: TTL circuit
A load of a TTL can be a resistor, a capacitor, or a current source. You will refer to a electrical characteristics part of a TTL Datasheet. They specify the test conditions and limits of a TTL.
    mohsin_kiet
Re: TTL circuit
Like any analog circuits TTL may have load connected from output to ground, from Vcc to output (open colector or push-pull configuration) or both.
So, the answer could be different for different configurations.
    mohsin_kiet
