Explanation of .lib, .lef, .DEF, .tf formats
vreddy
Full Member level 1
lef, def and liberty format
wat .lib, .lef, .DEF, .tf consists of ??
i know but still i wanna know in depth....
thanx
tlf tf synopsys
.lib contains the timing information of the cells.
.lef contains the physical information.
i think u mean .tlf and not .tf, .tlf as far as i know, also has timing information only.
.def is what we use in between steps (fp, routing etc).
Re: format
hey sree,
wta u said was right but wat def will do??
its design exchange format/?? or data exchange format??
format
its design exchange format. it conveys the physical design information. like i said, if u r using a p&r tool, if u floorplan and do placement, u can save it in def format. this can be imported again to complete the rest of the steps.
    vreddy
format
.lib: cell timing, area, power info
.lef: technology info + cell geometry info
.def: design netlist + geometry info
.tf: technology info, which is only for synopsys usage.
cadence uses: .lib, .lef, .def for library and design
synopsys uses: .lib, .tf, .pdef, Milkyway for library and design.
format
Thanks a lot
