matlab help for implementing Alamouti scheme.
sabari_eda
Newbie level 6
Newbie level 6
alamouti matlab
i need help in implementing Alamouti scheme for Space Time Block Codes using orthogonal designs.
can anybody help me pls?
alamouti scheme matlab
Hi ,
First u go through the IEEE paper by Alamouti .
"A Simple Transmit Diversity Technique for Wireless Communications" IEEE October 1998
It ll give you basic idea of implementing the Alamouti scheme.
All the Best
Regards,
Taraka
alamouti simulation matlab
I hv Alamouti simulation from mathwork and working on it, however i hv queries
Has anyone here ever worked on it?
Could you please help me?
Regards,
explain alamouti scheme
yaa i worked u post ur queries i ll try to clarify
Regards,
Goud
alamouti+matlab
in the simulation of alamouti using bpsk, i compare the performance between 2Tx x 1Rx and 2Tx x 2Rx
of course, at the same BER the second is better in SNR effect then the first
but i query that why the simulation of the second end at 7dB while the first is extended to 10dB?
regards,
matlab alamouti 2rx
Do you have enough samples to generate the BER calculation? For the 2TX-2RX simulation at about 7dB SNR the BER is about 10^-4. To simulate this BER you should have at least N = 10/Pb = 10 / (10^-4) = 10^5 samples (trials).
Regards,
Casey
matlab code for almouti scheme
yes i see, coz here N = 1000
so i hv changed and get the good result
but can u explain why there is a difference?
thanks
matlab simulation alamouti siso
thanks
As the BER gets smaller the number of trials required increases. Without enough trials you may not get any errors from the simulation. This is true for any BER simulation.
Casey
alamouti paper
Hi
when u implement an ALAMOUTI technique u need to estimate the channel. each path has a complex channel responce 'h'
the received signal at the 1st receiver anntenna is :
r1 = h1*s1 + h2*s2 + n1
where s1 and s2 are the symbols transmitted. and n1 is awgn
how do i estimate this channel responce 'h1' and 'h2' for the idependent channel paths?
Hi everybody.
Is there any one of you have code for alamouti scheme.i am very thankful if you ssend it to me.
I am actually working on SNR estimation.so far i do it for SISO.now i want to extend it to MIMO.so help me out.plz
thanks
my email:
engr_shahid@ieee.org
shah g said:
Hi everybody.
thanks
my email:
engr_shahid(at)ieee.org
Youn can find it here www.mathworks.com
tarakapraveen said:
Hi ,
All the Best
Regards,
Taraka
Mate can u upload or email at
collective.ajay(at)gmail.com for the matlab file for implementing the alamouti paper . i desperately need it for my assignment . thanks in advance
Added after 34 seconds:
tarakapraveen said:
Hi ,
All the Best
Regards,
Taraka
