Command in Hspice to see in which region the transistor is working
suhas_shiv
Full Member level 2
Full Member level 2
Hi all,
Is there any command in Hspice to see in which region the transistor is working?
HSpice Help needed
Hi
In recent hspice versions .op shows the region of transistors.
regards
HSpice Help needed
hspice demo.sp > demo.lis
Above is the hspice command to output lis file.
In demo file, add the line .op <time> where time is the time you want to check the operating point.
From lis file, check operating point and there u will see all the parameters for transistors in your netlist and you can observe the operation region
HSpice Help needed
.op will tell you,
but only dc, not trans, do you need monitor the work region in trans?
HSpice Help needed
EDSPICE of EDWInXP can also simulate the analog and digital designs
HSpice Help needed
i dont think there is any such provision in older version of HSPICE but might be there in newer ones...
