Does analog(or mixed mode) ic designer need script language?
leohart
Full Member level 4
Full Member level 4
TCL,Perl or sth else better?
Any suggestion?
ocean is a very good tool for cadence flow
    leohart
I think it is better if you know some scripting language...like perl .. tcl is not needed. Some time
you might need to manupulate few things in
your spice here and there so it's better to
automate it ..
    leohart
automatation will often cause wrong operation. If it's little change, do it by hand. if it's a very large task, tend to experienced script writer will be better.
    leohart
script can help you improve the efficiencym, but it will also cause the problem such as the wrong operation and more time to debug the script if it cause wrong problem.
anyway every coin has 2 sides.
    leohart
Re: Does analog(or mixed mode) ic designer need script langu
Perl, Skill and java
Salem
    leohart
Perl is a powerful tool to help you quickly summarize simulation measure result from hundreds of files covering all corners(vcc, temperature, process and etc), and we love those scripts, they are very easy and useful.
    leohart
Perl very usefull , specially if you use mentor tools, ocean very usefull for cadence tools, knowing skill language good but not important,
Sometimes it is useful to generate some data
I agree , perl is good enough if you need dealing with some netlist.
If your company has good CAD team, you don't have to do anything on script. But if not (most time, it does happen), ability using perl, SKILL(Cadence), Amply(Mentor), or maybe awk could give you more power to ease your design work.
Everything has advantages and disadvantages..
Scripting enables you to do things very quickly but you might end up debugging your script too...
But I believe: "If you are doing something twice, script it"... :D
perl, awk etc aid you in doing many things in a very simpler way..
