OradFarez
Can anyone recommend a little circuit I could use to switch the power input between a 5V DC jack and the 5V USB power pin input?
I'm trying to create a way to power a circuit from either but neither can dump back into the other and I don't want to use series diodes because of the voltage drop at high currents. Ideally, I would like power always in from the DC jack if available and only switch to USB if no DC adapter is available.
Thanks for any help someone may have.
