How to estimate the required buffring for a clock after place and route?
alzomor
Advanced Member level 2
Germany
Hi
Is it possible to do Clock tree synthesis "CTS" for vertix-4 FPGA using Xilinx ISE ?
And if possible How to do it?
Salam
Hossam Alzomor
www.i-g.com
Re: Clock tree synthesis
alzomor said:
Hi
Salam
Hossam Alzomor
www.i-g.com
In case of FPGA you can not do CTS, It is purely an ASIC part. Clock Routing resources are already available inside the FPGA. However You can select the low skew lines for your clock signal while doing synthesis with ISE. Low skew lines are specifically provided in the FPGA fabric for clock and other critical signals.
Salam
    alzomor
