Need help with programming QY-1604A LCD display
RollingEEE
Full Member level 3
Full Member level 3
Bangladesh
I have a QY-1604A LCD display, made in china, text based LCD display. Do any one of you have one? (I'll post more if I get a reply)
pinout lcd 4x16
can you say how much character it has in one line
and how many line it has
lcd display qy
Maybe it's 4 by 16 (4 lines by 16 character). Is it the same with hitachi models?
I have seen some LCD aside from hitachi, they follow the same protocol some how some of the difference are the pin number and pin layout.
If possible send some pictures.
    RollingEEE
led+ et led- lcd 2x16
lcd 1604a
Judging from the size (16x4) and the pinout, it seems HD44780-compatible. 90% of all text mode LCDs follow this.
http://home.iae.nl/users/pouweha/lcd/lcd.shtml seems like a good resource for controlling this type of LCDs.
fleury lcd lib
Base on the connector pins name, it is 100% HD44780-compatible LCD module. Your LCD library is for that kind of LCD module.
    RollingEEE
4x20 lcd display c51 program
Hi
all of charachter LCDs are similar to each other, in their read,write and commands.
all of charachter LCDs like 2x16,1x20,4x16,4x20,... have 16 pin's like a lcd that you sent it's picture.
i drived 2x16 lcd later and 4x20 charachter LCD with AVR recently.
maybe their ram address have difference.
    RollingEEE
16 line lcd pins layout
I think it is like the Hitachi
    RollingEEE
lcd 16x4 dealers mumbai
Yup it is Hitachi. Works fine with peter Fleur's LCD Library
lcd display led+ led-
For backlight,
regards
hd44780+lcd 4x20+avr
hey, RollingEEE
i have programmed an LCD with Hitachi HD44780-compatible if you want any help send me
    RollingEEE
    RollingEEE
lcd display qy-16
I am confirming it's a Hitachi.
This one is by and far the best LCD library for AVR. It is fully customizable. It's from Peter Fleury.
4x20 hd44780 avr library
Has anybody got a C program of how to program the LCD rather then assembly?
16/4 lcd display
@RollingEEE
For what cost did u purchase the QY-1604A part in china?
