Altera , Xilinx doubt
yamaha
hi all
pls help me out in this 1, i am a total naive in FPGA
I need to replace Xilinx XC2S100
with one of the following ICs
EP1C4F400C6
EP2C35F672C6
from altera, which 1 of them can i use
@ltera , Xilinx doubt
Simplest answer :
Refer to the device datasheet from Xilinx and Altera for those devices and you can get the idea to choose .
depends how match logic you need. select option to enble auto device select in quartus software
XC2S100 comes 3 packages
144-TQFP
208-PQFP
256-FBGA
456-FBGA
what is the package u have in ur existing design
ru sure about the altera part numbers
EP1C4F400C6 -400 FBGA
EP2C35F672C6 -672 FBGA
if ur not changing the hdl code, then i think u cud go for a lower version
