MATLAB wave recording problem
nwo4life
Junior Member level 3
wavwrite
HI,
I am having problems with MATLABs wave recording. I need to record a speech with fs = 8kHz at 8 bits/sample (one channel). Here is my code but it doesn't work,
y = wavrecord(5*fs, fs,1, 'uint8'); --> WORKS
wavplay(y,fs); -->WORKS
wavwrite(y, 8, 'test.wav');
x = wavread('test.wav');
The wavwrite command does not work properly, no errors occur but the when I play the file using Windows Media Player i don't hear anything. When I read the wav file back in to MATLAB its all the numbers in the vector are the same. i have also tried with two channels and the same result appears.
If anyone has an answer to this problem, please help me.
matlab recording problem
If someone can give me some help. I would really appreciate it.
THANKS
code for matlab wave recording
wavrecord with uint8 returns values from 0 to 255, but wavwrite expects -1 to +1.
Try this:
fs = 11025;
x = wavrecord(2*fs, fs, 'uint8');
wavplay(x, fs);
wavwrite((double(x)-128)/128, fs, 8, 'test.wav');
system('test.wav'); % Windows will play it
    nwo4life
wave recording in matlab
hello
i need complete coding of voice recognition
i have no time to submit my final year project and i worked alot on it but my coding has got some errors and i need a coding so that i can match mine and i can correct mine
kindly help me in giving me coding of voice recognition
