soheyl,
At the risk of stating a broad generality; an IIR filter will require fewer multiply-accumulate aperations than an FIR filter of equivalent performance. An easy way to get a high performance notch filter is to transform an analog filter notch filter using the bi-linear z transform.
Regards,
