What is the use of Tetramax?
absak
Junior Member level 2
I need to know for which purpose does Tetramax is used
Re: Tetramax
TETRAMAX is used for ATPG,
Regards,
Said.
Tetramax
hi all,
tetra max is used for genrating the atpg vector genration.there r diffrent tools r available for the same purpose like fastscan.
regards,
ramesh.s
Re: Tetramax
TetraMAX is a high-speed, high-capacity automatic test pattern
generation (ATPG) tool. It can generate test patterns that maximize
test coverage, using a minimum number of test vectors for a wide
variety of design types and design flows. It is well suited for designs
of all sizes up to millions of gates.
Tetramax
For ATPG coverage
Tetramax
I need this tool from where I can get it
Re: Tetramax
@Fatma: You should pay for a licence otherwise I don't think it is possible to download it anywhere!!
Thanks,
Moez
