[Required] Very simple Tx/Rx circuit for low data rate link
ahmad_abdulghany
San Jose, California, USA
simple tx & rx circuit
I need schematic for a very simple and implementable Tx and Rx with very low data rate requirements.
ASK, FSK, or any other modulation scheme is OK.
Excluding microcontroller chips, I hope not to use any IC's or ready made T/Rx modules.
Power is required to cover distance of about 20m (none-line of sight)
For antenna size issue, i hope to get operation frequency as high and in free band as possible.
If anyone succeeded to fetch similar circuit or close to its c/cs online or he already designed before, please share.
Thank you all,
Ahmad,
Re: [Required] Very simple Tx/Rx circuit for low data rate l
SA Ahmad,
I believe I've got what you want, it was a module that uses ASK scheme and operates in the 900MHz range.
It operated well in the 10 to 20 m range. Give me a day or two to check its model number or its manufacturer.
The problem is that I implemented it 6 years ago, so I guess you won't find the chip we used, but most surely you'll find something to start with.
Good luck and it's nice to hear from you once again :))
Salam.
Dear Ahmad,
Thank you for your nice reply :)
But what i actually was looking for a circuit diagram (discrete components).. also, for more clarification, i meant by the 20m, the spacial distance between Tx and Rx :) ..
I prefer not to raise in frequencies, i think 433MHz is enough!
However, as backup plane, please keep looking for the modules you stated above in your reply..
For others, please try to share also :)
Thank you all,
Ahmad,
