renwl
Advanced Member level 1
- Joined
- Apr 26, 2004
- Messages
- 452
- Helped
- 27
- Reputation
- 54
- Reaction score
- 5
- Trophy points
- 1,298
- Location
- shanghai,china
- Activity points
- 1,805
does the higher GBW mean faster settling time? why?
thanks!
thanks!
renwl said:does the higher GBW mean faster settling time? why?
thanks!
Sometimes you can improve it by GBW, assuming same stability.. but it is not always straightforward. Generally for higher GBW you need higher current, Bipolars increase gain by ~I, while mos~√I, (which means not too much). Also increasing current you can decrease output resistances, and also you need larger components, which means slightly higher capacitance...... Then comes stability...renwl said:if not consider the slew rate, can I improve the settling time when I increase the driving ability in the last stage?
thanks
bastos4321 said:Usually yes, but depends also on the slew-rate.
V(t)=c + k.e^(-t.gbw) this for a unity gain configuration.
so if you have a higher gbw you will have a fast response. If your gain is higher than one the expoent will be -t.gbw/gain.
For low speed applications you can be limitated by the slew-rate and not by the gbw.
Bastos
