MOSCAP @ nano meter process
simonkuo
Junior Member level 3
Dear all
In the nano meter process, the MOS gate leakage is too large that I can't use it as a capacitor.
Does anyone have good idea to solve the issue ?
I have to use the MOS as a capacitor or use the capacitor magnified technique.
Does anyone ever survey the "capacitor magnified technique" ?
Which circuit that you want to design?
PLL, regulator or ?
Try to use the thick oxide device.
    simonkuo
I want to design a PLL by advance CMOS process, but dut to the leakage issue, it is hard to design by thin oxide device.
I have the area limitation, I can't use the thick oxide, MIM or Fringe CAP to design.
Does anyone have the good idea?
You can use the varactor cap(nmos in nwell) as PLL loop filter cap.
BR
eric
1/4
Thanks Eric!
The nmos in nwell still has the gate leakage issue.
Thin Oxide devices have the same issue and spice model doesn't have the model to simulate.
use thick oxide varactor or device
