ATX Power Supply Tester
togarha
Member level 4
Member level 4
Hi!
Do yo know any schematic for an ATX Power Supply Tester? To test all voltages (may be test it when it gets so current it continues working? )
Thanks in advance...
Regards,
Thanks a lot,
And a cheaper and simple one?
Regards,
hi
i ned schematic atx power tester
tanks
Will this work with any ATX power supply?
Thank you.
I have always just used a 1 or 2 watt 12volt bulb, and a 5 watt 6 volt bulb. I agree that this doesn't stress the power supply, but at least you can see that it is working (and you can measure the voltage across the bulbs).
word of warning, don't run switch-mode power supplies without a load connected.
