Is there any mouse-base actions in Cadence (Strokes)??
ahmad_abdulghany
San Jose, California, USA
cadence strokes
Like Mentor tools, is there any mouse-based actions (unod, redo, zoom, etc.) in Cadence tools like Strokes in Mentor Tools?
Regards,
Ahmad,
how to use stroke editor cadence
as far as i knwo yes there are . but i donot know how to enable them
maybe someone have the answer
khouly
cadence concept strokes
i just know that mentor soft has this function.
regards
how to enable stroke editor in cadence
Al-7amdulillaah!! I found the solution!! The answer of the above question is: Yes, :D
There's a very usefull collection of mouse-based actions in Cadence layout as well as some other tools.. and they've the same name as in Mentor tools i.e. Strokes..
To load Storkes
- Once (e.g. to test their functionality)
type the following lines in the CIW:
load(prependInstallPath( "dfII/etc/sted/stroke.il"))
load(prependInstallPath( "dfII/etc/sted/defstrokes.il"))
hiLoadStrokeFile("def.strokes" "Layout")
- To permenantly load them, put the above lines in your .cdsinit file and restart Cadence.
To use stroke, To start a command with a stroke, press the right mouse button and draw one of the following strokes (see the attached image..This image was captured from Cadence Virtuoso® Layout Editor User Guide)
Notice that the arrows show the direction in which you draw the strokes. Note that there are two ways to start Zoom In with strokes.
I recommend that you refer to the mentioned manual for more details.. also, recommend to give a look to the SKILL file you loaded above..
Enjoy :)
Ahmad,
cadence concept enable strokes
You can use Binkey to redefine your keys :
<Btn1Click> , Shift<Btn1Click>, Alt<Btn1Click>, ShiftAlt<Btn1Click>, ...
Same with Btn2 and Btn3.
See your .cdsinit on how to define Bindkey.
defining mouse strokes for cadence concept
That's a good point!
but i have an old wonder !!!
Where should the .cdsinit exist?
There're many versions of .cdsinit file on my computer? Is there a specific function for each? Or what?
What is the default usage of it?
I opened it before, and what i found is some SKILL initializations and configurations, this one was under $CDS_ROOT/tools/dfII/local/samples but is there other copies?
Which one has the highest priority??
Ahmad,
cdsinit include
Regarding the .cdsinit file
usenet cadence newsgroups said:
the .cdsinit file is searched in this order :
1. <CDS_install_dir>/tools/dfII/local
2. the current directory "."
3. the home directory
But, once one .cdsinit file is found, the search stops. This means that if you have a
<CDS_install_dir>/tools/dfII/local/.cdsinit, it must EXPLICITELY load ~/.cdsinit and ./.cdsinit,
otherwise they won't be loaded at all.
Usually, a site .cdsinit would include something like
when( isFile("~/.cdsinit") load("~/.cdsinit") )
when( isFile("./.cdsinit") load("./.cdsinit") )
cadence redefine bindkey
no cadence tool has mouse based facitliy ..
only mentor has this facility and mentor has patented this .
so no one else can use this option
cadence mouse layout
I don't understand in fact what do u mean!! Although i put above how to use strokes in Cadence... didn't u read it?
Regards,
Ahmad,
