How can I program ARM microcontrollers?
thuvu
Member level 3
Member level 3
how to start programming arm
Hi everyone,
I want to start programming ARM microcontrollers and I was searching for some evaluation boards (Keil, Olimex...).
I noticed that the ARM chip is soldered on these boards and I can't use them to program other ARM for my PCB's.
(I used to work with AVR and STAK500 board that had sockets that I could program any ucontroller I wanted.)
Is there a solution to this? I want to be able to program different ARM chips and then solder them to my PCB's.
Do I need a JTAG programmer for this and if so what is the procedure that I have to follow?
Thank you very much in advance.
software for programming arm
Usually you program the Flash memory on this boards over the serial or USB port. Or you can program the MCU directly using JTAG logic on the board. You shouldn't need anything else besides a PC.
    thuvu
how to program arm7
Then I can create my own PCB, solder the parts and then program the ARM using a JTAG tool from any company. Right?
hjtag tms470 how to
Salam,
Most of ARMs microcontrollers had a built-in bootloader which it's used for programming built-in flash over UART using simple PC software.
Look to the datasheet of your device for more information.
Bye
    thuvu
rdi iar olimex
If ur using tms470 texas arm jtag is required,but for LPC2000 series using RS232 it has built in boot that can help u program the flash,free download front end tools for philips are available.i am using lpc2106 and i am programing using"ISP"(RS232)
    thuvu
programming internal flash through jtag arm nxp
Could you provide some useful links for programming with RS232.
Thank you
programmer arm
can you pls tell me which ARM chip are you using
    thuvu
how can programe arm
I am thinking to buy MCB2140 Evaluation Board from www.keil.com for ARM from Philips.
But I also want to program many of them for my projects and that's why I need your help.
The ULINK cost €300 and I am not going to pay for that if there is another way.
arm7 can bootloader
ARM can be programmed using a built in bootloader or in system programmer....
    thuvu
programing arm
LPC 214x are having inbuilt bootloader so no need to go for Ulink if you want this only to download code into internal flash but not for debug.
LPC flash utility is availavle at
for debug you can try 20 pin RDI from olimex with HJTAG debug agent which is available at www.hjtag.com
If you have any doubt pls ask
Thanks and Regards
Girish
    thuvu
programming arm
I recommend to start with some of the olimex's 'header' boards.
This is a boards with lodered MCU and all pins are on regular 100mill headers.
So, you can very easy move this board from project to project.
    thuvu
nxp flash programming utility
now a daya USB JTAG is a good choice
