fala
Full Member level 5
Hello, In many relays datasheet there is a parameter called "min permissible load" what exactly this parameter means? what happens if a relay that has a 1mV min permissible load be used to switch one nA current at low speed(1 switch every 10 minutes)?
Thank you
Thank you
