A question about conventional bandgap design.
sorata
Junior Member level 1
In a conventional bandgap, Point B is connected to the negative input of opamp while Point A is connected to the positive input of opamp.
My question is if the inputs of opamp is reversed, B to positive and A to negative, Is there any difference between this configuration and the former one ?
best regards,
and thanks
it will be unstable, because there is a positive closed loop in you circuit according to what you say
any detailed analysis ?
br,
thanks
from razivi book
    sorata
