Why is it said that opamp got infinite input impedance?
deepabhargavi
Junior Member level 2
why is it said that opamp got infinite input impedance?
Re: input impedance
nmo current passes into the opamp terminals.
AMRITH.S.
Re: input impedance
Asuming you are talking about an ideal op-amp.
There is no current flowing into the terminal.
This is like a open circuit connection.
Open circuit connect have infinite impedance.
Practical op-amp have leakage.
Very little current do flow into the terminal.
Althrough impedance is not infinite,
impedance is still consider large at the terminal.
www.siongboon.com
Re: input impedance
An opamp uses differential amplifier at the input stage. and the inverting and noninverting terminals are nothing but the two base terminals of the differential pair. now for an ideal opamp it is considered that the bjts of the diff amp are ideal so same current drawn by both, hence the net current flow to the opamp is zero.
therefore it is considered that the i/p impedance is infinite.
in practical case this is not true, and i/p impedance varies from 10Λ5 Ω onwards.
hope that clarifies your doubt
Re: input impedance
hi
the input impedance of opamp is ideally infinite but not practically.ideally becoz our basic assumption is the two sides of the diff.amp is symetric which is the first stage of opamp.
input impedance
For ideal opamp the input impedance in infinite so no current passes through the input terminals. actually the first stage of the opamp is an differential amplifier .
Re: input impedance
HI
if u check the input impedance using multimeter at the input terminals it will show u the value in some mega ohms. It means it does not draw any current for it operation.
