Recommend a book for total beginner in electronics and circuits
electronic principles by boylestad rapidshare
u better follow v k mehta
this is basic book and and an indian author
electronic principles malvino rapidshare
i would recommend sedra and smith and then directly to art of electronics...
by then you would have found your way...
AMRITH.S.
eng_moh17 said:
Hi
I am new to electronics and circuits, and I want to learn about them:?:.
Can any one tell me what's the best and easiest book to learn from.
I don't know any thing about electronics, nearly a white sheet:cry:, please help.
Thanks alot.
Mohammad El Shenawy
electronic circuits schilling belove rapidshare
If you want learn electronics, you should read Electronics Principles by Malvino. Read books by Boylestad.
electronic principles malvino english rapidshare
Start with basic circuit analysis.Then go for electronics.
It is better to know electrostatics to understand device physics.
best indian book on electric circuits
Electronic Devices and Circuit Theory by Boylestad & Neshlesky is a good book. You better try it.
best indian electrical circuit books
g.k mehta is for a very beginner who feels electronics difficult...
apart that g.k mithal is also ok...
once u understand fundamentals...better shift to millman and halkies..
millman
Get a book on technical mathematics, as it'll give you some math background, where you'll need, mostly, Algebra but some Trigonometry. ...Calculus will follow later...
Go with Boylestad or Malvino. Learn DC (direct current -- all voltages fixed) circuit analysis. Particularly you want to learn Ohm's Law, Kirchhoff's Voltage and Current Laws, the Voltage and Current Divider Rules, Nodal, Mesh, and Superposition.
Then move to AC (alternating current -- voltages change) circuit analysis, where you'll find that everything you learned with DC applies to AC, BUT with the addition of some Trigonometry. --- So get it all with DC first!!
Then, once you've done these things, move to Electronic Devices, things such as diodes, Bipolar Junction Transistors (BJT's), Field Effect Transistors (FET's), Metal Oxide Semiconductor FET's (MOSFET's), Silicon Controlled Rectifiers (SCR's) and such. These are all non-linear devices, but, if you got the DC and then the AC circuit analyses, then it's much easier to bridge into these devices.
Likewise, while you're studying the things above, thoughout it all, slowly build yourself an inventory of parts and equipment. First, before you start, get yourself a variable DC power supply. It needn't be anything fancy. Just get something that goes from zero to, maybe, 15 or 20 volts, with a current of up to 500mA (mA = milliamps = 1x10^-3 A) or so. Plus, Radio Shack sells a grab-bag of 1/4 Watt resistors ($12-13) and breadboards ($12? -- a white plastic board with holes, for quick and easy changes of components). Get a bag of these and at least one breadboard. Get a hold of some telephone wire, as it is the perfect guage for breadboarding circuits. Finally, you'll need a multimeter, so you can measure resistance, voltage, and current. Lowes sells some pretty good ones -- make sure your meter is fused, because you will make mistakes!!
Do the above and you'll be answering your own questions for the most part.
And of course, stay tuned to this site! There are some really good people here. Also, if you're so inclined, buy a subscription to Nuts and Volts magazine.
Ohm's Law: Learn it, use it, love it! It is the key!! E=IR -- voltage = current x resistance. Never forget it. Burn it into your soul.
tmh math formula rapidshare
Many books our friends introduced.
In my opinions, The Art of Electronics is a good book, but it is too big, too long, and somewhat out-of-dated, and not suitable for a beginner.
Try the set of books from Radio-Shack: Engineer's Mini-Notebook
(47MB) **broken link removed**
(37MB) **broken link removed**
The set consists of 13 books:
Engineer's Mini-Notebook - 555 Timer IC Circuits.pdf
Engineer's Mini-Notebook - Basic Semiconductor Circuits.pdf
Engineer's Mini-Notebook - Communications Projects.pdf
Engineer's Mini-Notebook - Digital Logic Circuits.pdf
Engineer's Mini-Notebook - Environmental Projects.pdf
Engineer's Mini-Notebook - Formulas, Tables and basic Circuits.pdf
Engineer's Mini-Notebook - Magnet and Magnet Sensor Projects.pdf
Engineer's Mini-Notebook - Op Amp IC Circuits.pdf
Engineer's Mini-Notebook - Optoelectronic Circuits.pdf
Engineer's Mini-Notebook - Schematic Symbols, Device Packages Design and Testing.pdf
Engineer's Mini-Notebook - Science Projects.pdf
Engineer's Mini-Notebook - Sensor Projects.pdf
Engineer's Mini-Notebook - Solar Cell Projects.pdf
Good luck
nguyennam
grob basic electronics rapid
Electronics Device by Floyd is an excellent book for beginners
electronic principles rapidshare
Boylestad's book: Electronic Devices and Circuit Theory is GREAT:)
it takes you from the very beginning
i always go back to it to refresh my memo
g.k.mithal rapidshare
1>electronic principles by malvino
2>art of electronics
3>electronics by hambley
basic electronics grob rapidshare
i am looking for this book any one can help me with link to download it , pleas i need your help
kamal77ly@yahoo.com
Re: Give me Advice
"Teach Yourself Electricity and Electronics" by Stan Gibilisco
"Getting Started in Electronics" by Forrest M. Mims
"Electronics For Dummies" by by Gordon McComb and Earl Boysen
Re: Give me Advice
the best books to learn abt electronocs are
1. integrated electronocs by millman and halkies.
2. micoelectronic ckts by sedra and smith
3.electroncs by boylested
Re: Give me Advice
First a textbook with examples so you learn basic passive elements and learn how to solve simple circuits. Starts with electrostatics and then electrodynamics, if those are correct terms in english. After that you should read about active components like transistors, diodes etc. basic active elements in short (also examples, solve them!). Then you should learn about feedback theory. After you understand all that, you do have a good starting point and you can start reading the already mentioned "Art of electronics" book. Great to begin with, lots of ideas there. That's a lot of work, but if you are interested, it will be fun.
About mathematics involved: diferential equations (multidimensional too) are a must, so are Fourier and Laplace transforms. After a while you should take a look into numerical mathematics just to get the feeling what is behind SW used to simulate circuits. If you are planing to venture into DSP you should read and understand basic about it too (Matlab is great for experimenting in DSP, btw).
Give me Advice
any electronics book that contains multiple choices? aside from MALVINO, FLOYD, GIBILISCO?
musch better if answers are included!
Re: Give me Advice
fundamental handbook of electrical science
fundamentals of electrical engineering and electronics
fundamental handbook of thermodynamics, heat transfer, and fluid flow
fundamental handbook of instrumentation and control
fundamental handbook of mathematics
fundamental handbook of chemistry
fuel cell handbook
organic chemistry handbook
handbook of chemical process hazard analysis
handbook of process safety management for highly hazardous chemicals
fundamentals handbook of engineering symbology, prints and drawing
fundamentals handbook of material science
fundamentals handbook of mechanical science
fundamentals handbook of nuclear physics and reactor theory
fundamentals handbook of classical physics
handbook of primer on spontaneous heating and pryophoricity
handbook of electrical safety
engineering statistics handbook
Gas Tungsten Arc Welding (TIG) Handbook
Electrical Engineering Cathodic Protection
Concrete Crack and Partial-Depth Spall Repair
Air Pollution Control Systems for Boiler and Incinerators
Security Engineering : Electronic Security System
Steam Power Plants
programmable logic controller (plc)
dynamic system modelling and control
integration and automation of manufacturing system
navy electrical and electronics training series (NEETS)
the art and science of protective relaying
coordinated power system protection
look on this side i hope it can help you .......
Re: Give me Advice
Good luck
nguyennam
file is not opening..but i want it..how to proceed...
