how to increase current in parallel port ?
ajaykumar988
Member level 5
Member level 5
how to amplify parallel port current
The port gives off eough voltage (the relay is rated at 5v, port output pins give of 5.something). The relay does not work; i dont think there is eough current.
Is it possible for me to tie multiple output pins together in some way to make the current higher while maintaining the same voltage level?
Would the parallel port itself have some sort of diode on the output pins so that electricity doesnt flow back into the circuit?
parallel port relay 2n2222
you should try using current amplifier
first isolate the parallel port with outside circuit for protection, then amplify the current of the signal either using opamp transisor or driving IC etc........
parallel port relays latch
The parallel port pins can not drive much .. the can probably source <3mA and sink <25mA (typical currents for the 74374 output latch) ..
You will need to "amplify" the ouput "voltage" signal by using external transistors ..
Here is one example:
                             Vcc
                              |    __|__
                            Relay   /^\  Diode 1N4002
                             Coil  /---\
                 4.7K    B |/  C
parallel port >-\/\/\/\/---|        NPN Transistor: BC547A or 2N2222A
data pi                    |\  E
                           | V
parallel port >--------------+
ground pin                   |
                          Ground
Regards,
IanP
parallel port increase
More simple and realiable if you use ULN2003
increase parallel port output
u can use optocoupler b/w the parallal port pin and relay, to get enogh cuurent to run relay.
search for optocoupler
increasing current in parallel
Use solid state relay based on photovoltaic element or integrated solid state relay. Look at IR site for details.
If you don't need galvanic isolation use approprated MOSFET as switch.
Any transistor interface would be able to drive the relay.
You can try a signal transistor (low current capacity) BC549.
Circuit reference to interface digital logic (0V 5V) to a mechnical relay.
see the source and sink current of parallel port. 2mA/24mA. So it won't be able to drive a relay. If you connect relay directly to parallel port then ur port will burn. Use some transistor with it. See the link below
Bibin John
www.bibinjohn.tk
