elf61
Member level 3
- Joined
- Sep 26, 2005
- Messages
- 58
- Helped
- 2
- Reputation
- 4
- Reaction score
- 1
- Trophy points
- 1,288
- Location
- against the computer!
- Activity points
- 1,710
hi - what is the LOW IMPEDANCE GROUND?
I am using a RS-485 Network in my circuit with ST485 ECDR IC.My circuit suddenly stop working,Stop means that during working slave stop to reply the master,then when I replace the IC it start to replay again.Transceiver was damaged .In the simplest terms:
If your question is about a specific circuit, it would help if you could post some details. A more detailed and precise answer would then be possible.
