STOIKOV
Full Member level 4
I executed some simulations in a MOS differential pair in order to verify some theory I read, and have some doubts.
If (Vin+ = Vin- = 0 volts) the current in each drain is Is/2. Isn't it supposed that with 0 volts in gates they are off ?
Also, when apply any DC value to the gates (Vin+ = Vin- = any volts) the current in each transistor is Is/2, no matther what the gates' DC voltages are. Why happens this instead off the quadratic law Id=K(Vgs-Vt)²
In summary, the drain currents are independient of the DC value in gates. The sum in both networks is always Is. These are the doubts I have and believe is due to the current source but do not explain well why.
