3.0 - Transformer Design
This next program is thanks to 'Particle' otherwise known as Geoff Sevart. With this, you can either analyse or design a transformer, although for proper design work you need to know a bit more than the program provides from its interface. Although fairly simple, it does give good results if you know what you are trying to achieve, and know some of the basics of the core material.
