How to load a program wrote for 89c51 to 89s51?
microlab
Full Member level 5
Full Member level 5
hai all
can we load a program wrote for 89c51 to 89s51?
or should we have tomake any changes?
what are the steps to be taken when doing so?
what's the difference between them?
ml
89s51 projects
Codes are the same .. the main difference is that you can program the "S" verison through ISP (in application) or using very simple programmers, while the "C" version still needs "full" parallel programmer ..
regards,
IanP
difference between 89s51 and 89c51
my few pieces of "S" version sometimes forget the flashed program. I stopped use it, but I cannot say that is general problem or only my few pieces. Atmel technicians did not help me.
89c51 vs 89s51
I don't have any problem with "S" version's flash.
AT89S51 has :
• Watchdog Timer
• Dual Data Pointer
watchdog 89c51
89s51 has more new feature than 89c51
such as
- ISP programming ( In system programming)
- Watch dog timer
therefore , its price is cheaper than 89c51
89s51 vs 89c51
Dual Data Pointer = 2 data pointers
Ref: **broken link removed**
Regards,
IanP
what is the difference between 89c51 and 89s51
actualy the 89c51 has 20 pin versions like 89c1051,89c2051 and 89c4051
that is good for little projects
89s51 and 89c51
s 51 is more cheaper than c 51 .But h/w suport and if you want to use the application for longtime better use c 51
