SD/MMC Card interface with PIC18F4550
DWC
Newbie level 1
Newbie level 1
South Africa
pic18f sd card
Hi
I am currently stuggeling to get my SD Card to interface with my PIC18F4550. I keep on getting a ERROR in Hyperterminal:
Test MMC driver
mmc init fault
Start...
I am using CCS compiler and interface the SD Card and MMC card via SPI. I just want to write data to the card and read it back via rs232. I included the circuit diagram as well as the code. Can SOMEBODY help me please?:cry:
Thank you
DWC
#include<18F4550.h>
#device *=16
#use delay (clock=4000000)
#use rs232(baud=9600, xmit=pin_c6, rcv=pin_c7, errors)
#fuses HS, NOLVP, NOWDT, PUT, BROWNOUT
#define MMC_CS    PIN_D0
#define MMC_CLK   PIN_D1
#define MMC_DI    PIN_D2
#define MMC_DO    PIN_D3
#include <mmc_spi.c>
int buffer[512];
int16 size=0;
main()
	int32 address=0;
	int *ptra;
	int16 f;
	unsigned int a=0;
	ptra = &(buffer[0]);
	printf("\n\rTest MMC drivers\n\r");
	printf(a);
	if(mmc_init()==0)
	   printf("\n\rmmc init ok\n\r");
	else
	   printf("\n\rmmc init fault\n\r");
	enable_interrupts(int_rda);
	enable_interrupts(global);
	printf("\n\rStart...\n\r");
	while(1)
		a = mmc_init();
	//starts to record the serial data and when have 512 bytes records it
	   if(size==512)
	      disable_interrupts(int_rda);
	//prints the buffer
	      printf("\n\rWhat enter the buffer:\n\r");
	      for(f=0;f<=511;f++)
	         printf("%c,",buffer[f]);
	//prints address of buffer to see if match the pointer
	      printf("\n\r");
	      printf("\n\rBuffer address            = %ld",&(buffer[0]));
	      printf("\n\rptra points to              = %ld",ptra);
	      printf("\n\r");
	//call the write block function from driver
	      if(mmc_write_block(address, size, &buffer[0])==0)
	         printf("\n\rwrite ok \n\r");
	      else
	         printf("\n\rwrite fault \n\r");
	//clear the buffer
	      for(f=0;f<=511;f++)
	         buffer[f]=0;
	      printf("\n\r");
	      printf("\n\r");
	//call the read block function from driver
	     if(mmc_read_block(address, size, &buffer[0])==0)
	         printf("\n\rread ok\n\r");
	      else
	         printf("\n\rread fault");
	//print the buffer to see if is the same as PIC send
	      printf("\n\r What the PIC receive must be the same as the buffer:\n\r");
	      for(f=0;f<=511;f++)
		      size=0;
		      address+=512;
		      printf("\n\rStart again\n\r");
#int_rda
void trata_rda()
	buffer[size]=getc();
	size++;
and the MMC driver Driver:
////////////////////// Driver for Multimedia Card ///////////////////////
////  mmc_init() - Reset and Initialize the MMC.  Returns zero if OK ////
////  mmc_modify_byte(address, val) - Modify the byte at address to  ////
////               change it's value to val.  Will read/write the    ////
////               entire 512 byte block but only change this        ////
////               specific byte.  Returns zero if OK.               ////
////  mmc_modify_block(address, size, *ptr) - Modifies the bytes     ////
////               to change their value to whats stored at *ptr.    ////
////               Will read/write the entire 512 byte block(s) but  ////
////               only change the values defined by ptr and size.   ////
////               Returns zero if OK.                               ////
////  mmc_write_block(address, size, *ptr) - Writes a 512 byte       ////
////               block to the MMC.  If size is less than 512 then  ////
////               unspecified data will be written as 0.  Returns   ////
////               zero if OK.                                       ////
////  mmc_read_byte(address,*ptr) - Reads the byte specified at      ////
////               address.  Result is saved to ptr.  Returns zero   ////
////               if OK.                                            ////
////  mmc_read_block(address, size, *ptr) - Reads the bytes          ////
////               specified at address.  Result is saved to ptr.    ////
////               NOTE: You might get an address error if you try   ////
////               to read over a page size.  For example, trying    ////
////               to read a block size of 512 starting at address   ////
////               0x100 may cause an error because you are reading  ////
////               two blocks.                                       ////
////  mmc_erase(address, blocks) - Erases the block specified at     ////
////               address.  Will erase the entire 512 byte block.   ////
////               If you wish to erase more blocks after specified  ////
////               block use the blocks parameter to specifiy how    ////
////               many extra blocks to erase.  Returns zero if OK.  ////
////              ~~~~~~~ MULTI-READ FUNCTIONS ~~~~~~~~              ////
////  mmc_read_enable(address, size) - Start multi-reads at          ////
////               specified address.  Size is the size of each      ////
////               individual read.  Returns zero if OK.             ////
////  mmc_read_mult_block(*ptr) - Reads data from the MMC, and saves ////
////               to ptr.  The number of bytes read is defined      ////
////               by mmc_read_enable().  You must call              ////
////               mmc_read_enable() before you can call this.       ////
////  mmc_read_disable(void) - Stop a multi-read.                    ////
////               MAY BE BROKEN.                                    ////
////        (C) Copyright 1996,2001 Custom Computer Services         ////
//// This source code may only be used by licensed users of the CCS  ////
//// C compiler.  This source code may only be distributed to other  ////
//// licensed users of the CCS C compiler.  No other use,            ////
//// reproduction or distribution is permitted without written       ////
//// permission.  Derivative programs created using this software    ////
//// in object code form are not restricted in any way.              ////
/////*** USER CONFIG ***/////
//SanDisk’s MultiMediaCards clock data in on the rising edge and out on the falling edge.
#ifndef MMC_CLK
#define MMC_CLK   PIN_B1
#endif
#ifndef MMC_DI
#define MMC_DI    PIN_B0
#endif
#ifndef MMC_DO
#define MMC_DO    PIN_B3
#endif
#ifndef MMC_CS
#define MMC_CS    PIN_B2
#endif
enum MMC_EC {
   MMC_EC_OK = 0,
   MMC_EC_NOT_IDLE = 1, //after reset command, device wasn't in idle state
   MMC_EC_NOT_INIT = 2, //after init command, device had an error
   MMC_EC_NO_CRC = 3, //CRC wouldn't turn off
   MMC_EC_SET_READ_BLOCKSIZE_FAIL = 4, //gave us an error during set blocksize
   MMC_EC_SET_WRITE_BLOCKSIZE_FAIL = 5, //gave us an error during set blocksize
   MMC_EC_SET_MULTI_BLOCKSIZE_FAIL = 6, //gave us an error during set blocksize
   MMC_EC_SET_WRITE_ADDRESS_FAIL = 7, //gave us an error when we told it we want to write block
   MMC_EC_BLOCK_NOT_WRITTEN = 8, //after sending block, it gave us this response
   MMC_EC_SET_READ_ADDRESS_FAIL = 9, //gave us an error when we told it we wanted to read block
   MMC_EC_ERASE_SECTOR_START_FAIL = 10, //mmc gave us an error when we set the start sector for erase
   MMC_EC_ERASE_SECTOR_END_FAIL = 11, //mmc gave us an error when we set the end sector for erase
   MMC_EC_ERASE_SECTORS_FAIL = 12, //mmc gave us an error when we told it to erase tagged sectors
   MMC_EC_BAD_STATE = 13,  //we cant start/continue a multi transfer because we didn't start/finish the last one
   MMC_EC_START_MULTI_READ_FAIL = 14, //mmc gave us an error when we started a multi-read
   MMC_EC_READ_NEXT_BLOCK_FAIL = 15, //mmc gave us an error when started to read the next block (in multi-read)
   MMC_EC_STOP_TRANSMISSION_FAIL = 16, //mmc gave us an error when tried to stup a multi read/write transmission
   MMC_EC_WRITE_ALWAYS_BUSY = 17 //after a block write, we waited longer than timeout period for busy signal to end
//#define MMC_DEBUG PRINTF      //uncomment this line to print out debug messages
#define MMC_DEBUG(a,b,c,d,e,f,g,h,i,j,k)   //uncomment this line to not print out debug messages
/////*** END USER CONFIG ***/////
//if you want to slow down the speed of the MMC clock, define delay_clk to a delay_xx() routine
//#define mmc_delay_clk() delay_us(1)
#define MMC_BLOCK_SIZE  512
int16 mmc_last_result=0;
// FUNCTIONS
//public functions
MMC_EC   mmc_init();
MMC_EC   mmc_modify_byte(int32 address, int8 val);
MMC_EC   mmc_modify_block(int32 address, int16 block_size, int *ptr);
MMC_EC   mmc_write_block(int32 address, int16 block_size, int *ptr);
#define  mmc_read_byte(a,p) mmc_read_block(a,1,p)
MMC_EC   mmc_read_block(int32 address,int16 block_size, int *ptr);
MMC_EC   mmc_erase(int32 address, int32 sectors);
MMC_EC   mmc_read_enable(int32 address, int16 block_size);
MMC_EC   mmc_read_mult_block(int *ptr);
MMC_EC   mmc_read_disable(void);
/* NOT TESTED ROUTINES
short mmc_write_enable(int32 address, int16 block_size);
short mmc_write_mult_block(int *ptr);
void  mmc_write_disable();
void  mmc_read_csd(int *ptr);
void  mmc_write_csd(int *ptr);
//private functions
int16 mmc_send_cmd(int cmd, int32 arg, int mode);
void  mmc_send_data(int d_byte);
int   mmc_read_data();
void  mmc_select(void);
void  mmc_deselect(void);
int1  mmc_wait_for_not_busy(int16 to); //to in 8 clocks
int1  mmc_receive_data(int8 *ptr, int16 size);
// GLOBALS
enum {MMC_STARTUP_STATE=0, MMC_STANDBY_STATE=1, MMC_WRITE_STATE=2,
      MMC_READ_STATE=3, MMC_ERASE_STATE=4} mmc_state=MMC_STARTUP_STATE;
//holds the current block size of our multi-read or multi-write routines
int16   mmc_blk_size;
#define MMC_CMD_GO_IDLE_STATE          0
#define MMC_CMD_SEND_OP_COND           1
#define MMC_CMD_STOP_TRANSMISSION      12
#define MMC_CMD_SET_BLOCKLEN           16
#define MMC_CMD_READ_SINGLE_BLOCK      17
#define MMC_CMD_READ_MULTITPLE_BLOCK   18
#define MMC_CMD_WRITE_BLOCK            24
#define MMC_CMD_TAG_SECTOR_START       32
#define MMC_CMD_TAG_SECTOR_END         33
#define MMC_CMD_ERASE                  38
#define MMC_CMD_CRC_ON_OFF             59
//************************* Public Functions ****************************//
// mmc_init()     Initializes the unit.
// Paramaters:    <none>
// Returns:       0 if initiated correctly
//                Non-zero if initiation failed
// Special Info:  This should be called immediately to initialize
//                the multi media card.
MMC_EC mmc_init(void)   {
   int16 result;
   int8 to=50;
   mmc_state = MMC_STARTUP_STATE;
   output_high(MMC_CS);
   output_high(MMC_DO);             // set pin levels
   output_high(MMC_CLK);
//   output_low(MMC_CLK);
   output_float(MMC_DI);
   delay_ms(15);
   do {
      mmc_select();
      result=mmc_send_cmd(MMC_CMD_GO_IDLE_STATE,0,1);
      mmc_deselect();
      if (result==1)
         break;
      else {
         delay_ms(10);
         to--;
   } while (to);
   if (result!=1) {
      MMC_DEBUG(" ERR: after reset, device isn't idle");
      return(MMC_EC_NOT_IDLE);
   to=50;
   do {
      mmc_select();
      result = mmc_send_cmd(MMC_CMD_SEND_OP_COND,0,1);                // puts card into ready state
      mmc_deselect();
      if (result && (result!=1)) {
         MMC_DEBUG(" ERR: after init we got a funky error %LX", result);
         return(MMC_EC_NOT_INIT);
      else if (result==1) {
         to--;
         delay_ms(1);
      else
         break;
   } while (to);     // loop until not busy
   MMC_DEBUG(" init cmd returns: %X\n\r",result);
   mmc_select();
   result=mmc_send_cmd(MMC_CMD_CRC_ON_OFF,0,1);
   mmc_deselect();
   if (result) {
      MMC_DEBUG(" ERR: CRC didn't turn off");
      return(MMC_EC_NO_CRC);
   mmc_state = MMC_STANDBY_STATE;        // set current state
   return(MMC_EC_OK);
// mmc_modify_block()
//                Writes a block to the MMC.  This routine will read the
//                entire 512 byte block first, and then make modifications
//                to that in RAM and save it back to MMC.  Therefore, this
//                is the function to use if you want to write data that is
//                less than the size of the block (512 bytes)
// Paramaters:    address:  address to write to
//                ptr:      data byte to write
//                size:     number of bytes to write
// Returns:       TRUE  if write worked correctly
//                FALSE if failed
MMC_EC mmc_modify_block(int32 address, int16 size, int *ptr)   {
   int8 mmc_buffer[MMC_BLOCK_SIZE];
   int val;
   int16 i;
   int32 block_start;
   int16 num;
   MMC_EC res;
   val = 0;
   block_start=address & 0xFFFFFE00;
   i=address-block_start;
   while(size) {
      res=mmc_read_block(block_start, MMC_BLOCK_SIZE, mmc_buffer);
      if (res) {
         MMC_DEBUG(" cannot read 512 byte block.  nothing written! \n\r");
         return(res);
      MMC_DEBUG(" read 512\r\n");
      if ((size+i)>MMC_BLOCK_SIZE) {num=MMC_BLOCK_SIZE-i;} else {num=size;}
      memcpy(&mmc_buffer[i],ptr,num);
      res=mmc_write_block(block_start, MMC_BLOCK_SIZE, mmc_buffer);
      if (res) {
         MMC_DEBUG(" cannot write MMC_BLOCK_SIZE byte block\r\n");
         return(res);
      MMC_DEBUG(" 512 written\r\n");
      ptr+=num;
      block_start+=MMC_BLOCK_SIZE;
      size-=num;
      i=0;
   return(MMC_EC_OK);
MMC_EC mmc_modify_byte(int32 address, int8 val) {
   return(mmc_modify_block(address,1,&val));
// mmc_write_block()
//                Writes a block to the MMC.  The address must start at the
//                beginning of a block (every 512 bytes).
//                size:     number of bytes to write from RAM
//                FALSE if failed
// Notes:         If address does not start at a block boundry, the MMC will
//                give you an error.
//                If you have a size less than 512 the rest of the data will
//                be saved as 0.
MMC_EC mmc_write_block(int32 address, int16 size, int *ptr)   {
   int16 j;
   int8 val;
   int8 res;
   mmc_select();
   res=mmc_send_cmd(MMC_CMD_SET_BLOCKLEN, MMC_BLOCK_SIZE, 1);
   mmc_deselect();
   if (res)
      MMC_DEBUG(" set block size failed\n\r");
      return(MMC_EC_SET_WRITE_BLOCKSIZE_FAIL);
   mmc_select();
   res=mmc_send_cmd(MMC_CMD_WRITE_BLOCK,address,1);   // command to write byte at address
   if (res)
      MMC_DEBUG(" write byte failed.  Nothing written!\n\r");
      mmc_deselect();
      return(MMC_EC_SET_WRITE_ADDRESS_FAIL);
   mmc_send_data(0xFF);                    // send nothing for 8 bits
   mmc_send_data(0xFE);                    // send start bit
   for(j=0; j<MMC_BLOCK_SIZE; j++)
      if (size) {
         val=*ptr;
         ptr++;
         size--;
      else {
         val=0;
      mmc_send_data(val);                    // writes the byte
   mmc_send_data(0xFF);  //crc
   val = mmc_read_data() & 0x1F;
   MMC_DEBUG(" write data returned:  %X\n\r",val);
   if (!mmc_wait_for_not_busy(1000)) {
      MMC_DEBUG(" ERR: mmc spi is busy\r\n");
      return(MMC_EC_WRITE_ALWAYS_BUSY);
   mmc_deselect();
   if(val!=5)         // if not stored correctly
      MMC_DEBUG(" data not stored\n\r");
      return(MMC_EC_BLOCK_NOT_WRITTEN);
   MMC_DEBUG(" data was stored\n\r");
   return(MMC_EC_OK);
// mmc_read_block()
//                Reads a single block to the mmc
// Paramaters:    address:    address to read from
//                block_size: number of bytes in block
//                ptr:        value to store bytes
// Returns:       TRUE   if valid data
//                FALSE  if not valid data
MMC_EC mmc_read_block(int32 address, int16 block_size, int *ptr)   {
   int16 i;
   int16 result;
   mmc_select();
   result=mmc_send_cmd(MMC_CMD_SET_BLOCKLEN,block_size,1);
   mmc_deselect();
   if (result) {   // sets the block size
      MMC_DEBUG(" ERR: couldn't set read block size\r\n");
      return(MMC_EC_SET_READ_BLOCKSIZE_FAIL);
   mmc_select();
   result=mmc_send_cmd(MMC_CMD_READ_SINGLE_BLOCK,address,1);
   if(result)      // command to read byte at address
      mmc_deselect();
      MMC_DEBUG(" ERR: couldnt set read address\r\n");
      return(MMC_EC_SET_READ_ADDRESS_FAIL);
      mmc_receive_data(ptr,block_size);
      mmc_deselect();
      return(MMC_EC_OK);
// mmc_erase()
//                Erases sectors on the mmc
// Paramaters:    address:  sector number
//                sectors:  number of sectors to erase
// Returns:       <none>
// Calls:         send_cmd
// Special Info:  All data will be lost in the sectors!
MMC_EC mmc_erase(int32 address, int32 sectors) {
   int32 sector_start;
   int32 sector_end;
   int8 res;
   if (sectors) {
      sector_start=address/MMC_BLOCK_SIZE;
      sector_end=sector_start + sectors - 1;
         mmc_select();
         res=mmc_send_cmd(MMC_CMD_TAG_SECTOR_START, sector_start, 1);
         mmc_deselect();
         if (res) {return(MMC_EC_ERASE_SECTOR_START_FAIL);}
         mmc_select();
         res=mmc_send_cmd(MMC_CMD_TAG_SECTOR_END, sector_end, 1);
         mmc_deselect();
         if (res) {return(MMC_EC_ERASE_SECTOR_END_FAIL);}
      mmc_select();
      res=mmc_send_cmd(MMC_CMD_ERASE,0,1);
      mmc_deselect();
      if (res) {return(MMC_EC_ERASE_SECTORS_FAIL);}
   return(MMC_EC_OK);
//                Enables streamming read mode for the mmc
// Paramaters:    address:    start address
//                block_size: size of one block
// Returns:       TRUE if enabled
//                FALSE if error
// Calls:         send_cmd
//                read_cmd
// Special Info:  Use this to enable multiple reads, starting at
//                the address passed in.
//                NOT TESTED
MMC_EC mmc_read_enable(int32 address, int16 block_size)  {
   int16 ret;
   if(mmc_state!= MMC_STANDBY_STATE) {   // make sure not currently in other state
      MMC_DEBUG(" ERR: not in good state for multi-read\r\n");
      return(MMC_EC_BAD_STATE);
   mmc_state = MMC_READ_STATE;          // set to correct state
   mmc_blk_size = block_size;
   mmc_select();
   ret=mmc_send_cmd(MMC_CMD_SET_BLOCKLEN,block_size,1);
   mmc_deselect();
   if(ret) {        // sets the block size
      MMC_DEBUG(" ERR: multi read didnt set block\r\n");
      return(MMC_EC_SET_MULTI_BLOCKSIZE_FAIL);
   mmc_select();
   ret=mmc_send_cmd(MMC_CMD_READ_MULTITPLE_BLOCK,address,1);
   if(ret) {           // sets the address to read from
      MMC_DEBUG(" ERR: doesnt like multi read\r\n");
      mmc_deselect();
      return(MMC_EC_START_MULTI_READ_FAIL);
   return(MMC_EC_OK);
// mmc_read_mult_block()
//                Reads a data byte from the mmc
//                FALSE if error
// Calls:         read_data
// Special Info:  Use this after enabling multiple reads.  This
//                reads only a single byte.  Call multiple times
//                to read multiple bytes.
//                NOT TESTED
MMC_EC mmc_read_mult_block(int *ptr) {
   if(mmc_state != MMC_READ_STATE) {     // check for correct state
      MMC_DEBUG(" err: bad state\r\n");
   if (!mmc_receive_data(ptr,mmc_blk_size)) {
      MMC_DEBUG(" err: cant read multi block\r\n");
      mmc_deselect();
      return(MMC_EC_READ_NEXT_BLOCK_FAIL);
   return(MMC_EC_OK);
// mmc_read_disable()
//                Disables multiple reads to the mmc
// Returns:       <none>
// Calls:         send_cmd
// Special Info:  Use this when done with multiple reads.  This
//                disables reading, and will cause an error if the
//                user tries another read.
//                NOT TESTED
#define mmc_read_disable() mmc_stop_transmission()
MMC_EC mmc_stop_transmission(void) {
   int8 res;
   res=mmc_send_cmd(MMC_CMD_STOP_TRANSMISSION,0,1);
   mmc_deselect();
//   if (res) {
//      MMC_DEBUG(" err: couldnt stop transmission\r\n");
//      return(MMC_EC_STOP_TRANSMISSION_FAIL);
   return(MMC_EC_OK);
// mmc_write_enable()
//                Enables streamming write mode for the mmc
//                FALSE if error
// Calls:         send_cmd
//                read_cmd
// Special Info:  Use this to enable multiple writes, starting at
//                NOT TESTED
/* NOT TESTED
short mmc_write_enable(int32 address, int16 block_size) {
   if(mmc_state!= STANDBY_STATE)    // make sure not currently in other state
      return FALSE;
   mmc_state = WRITE_STATE;         // set to correct state
   if (mmc_send_cmd(16,block_size,1))         // sets the block size
      return false;
   if(mmc_send_cmd(25,address,1))            // sets the address to write to
      return false;
   return TRUE;
// mmc_write_mult_block()
//                Writes a data byte to the mmc
// Paramaters:    The byte to write
//                FALSE if error
// Calls:         send_data
// Special Info:  Use this after enabling multiple writes.  This
//                writes only a single byte.  Call multiple times
//                to write multiple bytes.
//                NOT TESTED
/* NOT TESTED
short mmc_write_mult_block(int *ptr)   {
   int i;
   if(mmc_state != WRITE_STATE)     // check for correct state
      return FALSE;
   mmc_send_data(0xFD);
   for(i=0; i<blk_size; i++)
      mmc_send_data(*ptr++);            // write the data byte
   mmc_send_data(0);                    // blank crc
   mmc_send_data(0);
   if(read_data_response()==5)   // if not stored correctly
      return TRUE;
   else
      return FALSE;
// mmc_write_disable()
//                Disables multiple writes to the mmc
// Returns:       <none>
// Calls:         send_cmd
// Special Info:  Use this when done with multiple writes.  This
//                disables writing, and will cause an error if the
//                user tries another write.
//                NOT TESTED
/* NOT TESTED
void  mmc_write_disable()  {
   mmc_state = STANDBY_STATE;
   mmc_send_cmd(12,0,1);      // stops multiple block writes
/* NOT TESTED
void  read_csd(int *ptr)   {
   int i;
   mmc_select();
   mmc_send_cmd(9,0,1);
   mmc_read_data();
   for(i=0;i<16;i++)
      *ptr++ = mmc_read_data();
   mmc_read_data();
   mmc_read_data();
   mmc_deselect();
/* NOT TESTED
void  write_csd(int *ptr)  {
   int i;
   mmc_select();
   mmc_send_cmd(27,0,1);
   for(i=0;i<16;i++)
   mmc_send_data(0);
   mmc_send_data(0);
   i= mmc_read_data();
   MMC_DEBUG(" write csd gets %X\n\r", i);
   mmc_deselect();
//************************ Private Functions ****************************//
// mmc_send_cmd()
//                sends a command to the mmc, then gets the response
// Paramaters:    cmd:  command number
//                arg:  32 bit argument
//                mode: what kind of response should we get?
//                  if mode==1, Format R1 (one byte response)
//                  if mode==2, Format R2 (two byte response)
//                  if mode==3, Format R3 (five byte response)
//                  if mode==0 then don't get a response
// Returns:       Error code given by MMC (R1, R2 or R3 format)
//                0 if no error.
int16  mmc_send_cmd(int cmd, int32 arg, int8 mode)  {
   int i;
   int out[6];
   int8 to=50;
   int8 bits;
   if (!mmc_wait_for_not_busy(50)) {
      mmc_last_result=0xFFFF;
      return(mmc_last_result);
   out[0] = cmd | 0x40; // bits 47 to 40
   out[4] = make8(arg,0);     // bits 15 to 8
   out[3] = make8(arg,1);     // bits 23 to 16
   out[2] = make8(arg,2);     // bits 31 to 24
   out[1] = make8(arg,3);     // bits 39 to 32
   if (cmd==0) {
      out[5] = 0x95;
   else {
      out[5] = 0xFF; //ignore the CRC
   for (i=0;i<6;i++)
      mmc_send_data(out[i]);
   MMC_DEBUG("\n\r sent cmd %U, arg %LU\n\r", cmd, arg);
   if (!mode) {return(0);}
   if(mode == 1)
      bits = 8;
   else if(mode == 2)
      bits = 16;
   else if(mode == 3)
      bits = 48;
   else
      bits = 0;
   for(i=0;i<5;i++)
      out[i] = 0;
   i=0;
   do {
      i++;
      mmc_delay_clk();
      mmc_delay_clk();
   } while((input(MMC_DI))&&(to--));
   if (input(MMC_DI)) {
      MMC_DEBUG(" err: no start bit waiting for response\r\n");
      mmc_last_result=0xFFFE;
   shift_left(out,5,input(MMC_DI));  // input start bit = '0'
   mmc_delay_clk();
   for(i=0; i<(bits-1); i++)
      mmc_delay_clk();
      mmc_delay_clk();
   MMC_DEBUG(" i=%U\r\n",i);
   MMC_DEBUG(" cmd data in = %x", out[0]);
   do {
      out[0]=mmc_read_data();
   } while ((bit_test(out[0],7))&&(to--));
   if (mode==2) {
      out[1]=mmc_read_data();
   if (mode==3) {
      out[2]=mmc_read_data();
      out[3]=mmc_read_data();
      out[4]=mmc_read_data();
   if(mode == 1) {
      MMC_DEBUG("\r\n");
      mmc_last_result=out[0];
   else if(mode == 2) {
      MMC_DEBUG(", %x\r\n",out[1]);
      mmc_last_result=make16(out[1],out[0]);  //not tested
   else if(mode == 3) {
      MMC_DEBUG("\r\n");
      mmc_last_result=out[0];  //not tested
void mmc_spi_exchange(int8 out, int8 *in) {
   int8 i;
   for (i=0;i<8;i++) {
      output_bit(MMC_DO, shift_left(&out,1,0));
      mmc_delay_clk();
      mmc_delay_clk();
      shift_left(in,1,input(MMC_DI));
      mmc_delay_clk();
      mmc_delay_clk();
// mmc_send_data()
//                sends a data byte to the mmc
// Paramaters:    the byte sent
// Returns:       nothing
// Special Info:  You can use this function to generate 8 clocks with no data.
//                Use a paramater of 0xFF to do this.
void mmc_send_data(int8 data) {
   int8 null;
   mmc_spi_exchange(data,&null);
// mmc_read_data()
//                software SPI bit banging to read from MMC
// Paramaters:    none
// Returns:       data byte read
// Special Info:  used for read data respose to write
int8 mmc_read_data(void) {
   int8 ret;
   mmc_spi_exchange(0xFF,&ret);
   return(ret);
// mmc_select()
//                Sets the MMC CS so the MMC is selected
// Paramaters:    none
// Returns:       none
// Special Info:  Must be called before a mmc_send_cmd()
void mmc_select(void) {
#ifdef MMC_UNIT_ID
   int i;
   int1 old_gie;
   // If program uses interrupts disable them
   // during this function
   #if defined(__PCM__)
      old_gie=bit_test(*0x0b,7);
      bit_clear(*0x0b,7);
   #elif defined(__PCH__)
      old_gie=bit_test(*0xFF2,7);
      bit_clear(*0xFF2,7);
   #endif
   do {
      do {
         while(!input(MMC_CS));
         delay_us(10);
      } while(!input(MMC_CS));
      output_low(MMC_CS);
      for(i=1;i<=MMC_UNIT_ID;i++)
         delay_us(25);
      output_float(MMC_CS);
      delay_us(5);
   output_low(MMC_CS);
   for(i=1;i<=(8-MMC_UNIT_ID);i++)
       delay_us(25);
   if (old_gie) {
         bit_set(*0x0b,7);
         bit_set(*0xFF2,7);
      #endif
#else
   output_low(MMC_CS);
#endif
// mmc_deselect()
//                Sets the MMC CS so the MMC is no longer selected.
//                Also generates 8 blank clocks which the MMC uses to
//                finish the CMD.
// Paramaters:    none
// Returns:       none
// Special Info:  Most of the time must be called after a mmc_send_cmd(), after
//                the cmd has processed.
void mmc_deselect(void) {
   mmc_send_data(0xFF);  //send 8 clocks for MMC to get ready for next command
// mmc_wait_for_not_busy()
//                Waits for the DI line to indicicate that the MMC is no longer
//                busy.
// Paramaters:    Number of 8 clocks we should wait until line goes high.
// Returns:       TRUE if not busy, FALSE if busy.
int1  mmc_wait_for_not_busy(int16 to) {
   int8 i;
   do {
      for (i=0;i<8;i++) {
         mmc_delay_clk();
         mmc_delay_clk();
   }  while((!input(MMC_DI))&&(to--));
   if (input(MMC_DI))
      return(TRUE);
   return(FALSE);
int1 mmc_receive_data(int8 *ptr, int16 size) {
   int8 to=50;
   int16 i;
   do {
      if (mmc_read_data() == 0xFE)
         break;
      else {
         to--;
         delay_ms(1);
         if (!to) {
            MMC_DEBUG(" ERR: didnt get repsone when reading\r\n");
            return(FALSE);
   } while (to);
      for(i=0; i< size; i++) {
         *ptr = mmc_read_data();  // reads each byte
         ptr++;
      mmc_read_data();
      mmc_read_data();
      return(TRUE);
sd card pic18f
I use this circuit and this driver...
To init and write or read or read i put a cicle for and if the init fauls i try again... sometimes only ate second time i can init the card...
do{
   if(mmc_init()!=0)                                     //init drive mmc
      send++;
   else
      command_send=1;
   if(send>=10)
      fprintf(pc,"\n\rERRO AO INICIAR O CARTAO");
      output_high(pin_a0);
      while(1);
   }while(!command_send);
where did u get this code from? did you write it your self? where did you get the reference from?
Re: pic18f sd card
Hello!
Do you really think somebody is going to read and (try to) understand your
hundreds of lines of code and on top of that debug it?
I think the fastest way will be to debug it yourself.
For what I understand, your program involves SD card and hyperterminal.
Try to do it gradually:
1. Try to initialize your card without file system
2. Try to write a raw block in your SD card
To be sure that it has actually been written:
- declare an array of 512 bytes;
- Fill it with 0s.
- Read block 0 of the sd card and verify that the array has changed.
- Write '1' 512 times to your array (fill it with 1)
- Write the array at 0
- Fill your array with 0s this time
- Read block 0 (at this point it should be filled with the 1s you have just written)
3. Similarily, try to read and write other blocks at other locations.
4. Now you know that the SD card is initialized and works, so you may integrate
the FAT file system. Reformat your sd card since you have written arbitrary blocks.
5. Try to follow with the debugger, whether you can parse the MBR.
6. Try to open one file and read its first block.
7. Try to create one file, and write "hello" in it. Verify that you can read it on a PC
8. Try to write more than 512 bytes, and verify that you can read it on a PC
9. Try to write more than 1 cluster and verify that you can still read it on a PC.
10. Once you are sure of your code, integrate the serial port. Might be useful to
test the serial port alone.
Then if something does not work, you may come back with accurate and focused
questions. But if you simply say "my program doesn't work", I guess you will get
as much help as you have put effort in your program.
Dora.
DWC said:
Hi
Test MMC driver
mmc init fault
Start...
Thank you
DWC
[ code deleted]
