interfacing 89c52 with PC
omrox
Junior Member level 1
89c52 interfacing with pc
can java be used to interface 89c52 with the PC, via serila port ? if no why and which option is prefered .
interfacing 89s52 with serial port
well, i've never tried to interface any uC with the pc using java. But i know it is possible to work with hyper terminal + any uc you want.
I guess it is possible, and all you need to do is find out how to work with serial port in java.
good luck
89c52interfacewithpc
wot is the most prefferd programmin language used to interface. graphic C..
hai
you can interface the uc with the pc
via comport
it's very easy
program the uc at aspecified baud rate
write program for ur pc in any language,which will read the com port
that's it
sun
I wrote BCB app for win 2000
to access the COMx port I used:
sprintf(szCOMport, "COM%d", ComPortNr); // port file name
hComm = CreateFile(szCOMport,
GENERIC_READ | GENERIC_WRITE,
0,
0,
OPEN_EXISTING,
FILE_ATTRIBUTE_NORMAL ,// FILE_FLAG_OVERLAPPED,
NULL);
yuv
    omrox
