Where does CMOS output short circuit limiting come from?
Euler's Identity
Full Member level 1
shorting cmos output
In a recent experiment I performed after fielding another's question in another thread (CMOS NAND), I wired a cd4001BE NOR gate as follows.
Vdd = 6V/5A source
Vss = 0v
A=B=X=Vss
To my surprise I found that the current drawn from the supply was only around 8mA.
6v/8mA=0.75x10^3 = 750Ω
Where did that 750Ω limitng resistor come from? In my research, the highest resistor I've found is 15-30Ω + Rds_on in series with a CMOS output (via cd4007 datasheet.)
What gives? Is an on p-channel MOSFET really 720Ω? (According to a cd4001 datasheet, the 1/4 cd4001 is actually a NAND with inverters on its inputs and output. So, it's really just a single on p-channel device when its inputs are low, not a series.)
I'm perplexed...
Added after 4 hours 7 minutes:
I'm still perplexed, been digging and digging.
Does anyone know?
Thank you. I did see that graph, in miniature mind you, but I saw it. Likewise, I saw the internal schematic.
From these things and, as well, my experiment, I could only conclude that an on p-channel MOSFET is indeed over 700Ω from drain to source.
Isn't that rather high for a full on device??
Are we sure there isn't more to the internal circuit, something that's adding R?
Logic gates aren't designed to drive relays and motors - they're designed to drive other logic gates. When you consider that the input capacitance of a 4000 series gate is typically 5pF, a fanout of ten (50pF) would yield a risetime of around 50ns - plenty fast for the specs of the CD4000 series.
Vo ---- R ----- Vin ------ C ------ Vss
Vin = Vo(1 - e^-(t/τ))
Vin
Vo
1 - e^-(t/τ)
so
e^-(t/τ)
1 - Vin/Vo
inverting
-t/τ
ln(1 - Vin/Vo)
Therefore, w/R=750Ω and C=Cin=50pF,
-t = 750Ω*50pF*ln(1 - 2.5/5) = 37.5ns*-0.693 = -26ns
Ok, I'll buy it. :)
I never realized Ron was that large. Thanks!
