-10 volts voltage regulator IC
Electronica
Full Member level 1
plz tell me any -10v fixed negative voltage regulator IC
79xx series give negative fixed voltages
......xx stands for d voltage u desire
u will get datasheets by simply searching google
hi
as for the series 79xx it is for definte voltages and you don t determine it as far as I remember 10 volt is not included.
As fixed negative 10V voltage regulators are not available you can use the LM7908 (-8V) voltage regulator and add 2.1V zener diode between its COM pin and 0V .. see picture below ..
However, if you can get hands on the LM337 adjustable voltage regulator - with only 2 external resistors - you will be better off than with the LM7908+2.1V zener ..
Regards,
IanP
