gbowne1
Newbie level 6
pins 80c31
I am designing and building a radio transmitter that works in the bands from 1,800 KHz to 30MHz.
It is based on a 10 year old design that uses a 3 chip computer using the 80C31 and a 27C64. The EPROM is supposed to have 2,008 lines of assembly code.
I am redesigning the circut so that it is not so modular. The original design was designed to be housed in a small chassis. I now have two rackmount chassis that I wish to use with the project, one 12" high and the other 6" high. They both go about 22" front to back. The design is spaced over about 7 different PC boards. I would like to either slim it down to about 3 boards or design a planar system using ISA type 8 or 16 bit bus cards.
I am intending on updating to 2006 technology.
The original design used a 2 row, 16 character per row. LCD display that is backlit. I was planning on doubling that to 4 x 32.
I need to know what I could change the controller to in the update.
I can post text files of component lists from the original design or parts of the original text.
Greg
Greg
