IR distance sensors for detecting wall at about 3 to 5 cms
alvarorahul
Full Member level 1
hi guys n gals
i am preparing for micromouse
so i want an efficient mechanism to detect the presence and absence of a wall abt 3-5 cms from the machine
i was thinking of using tsop 1738 but wid the transmitter that i made i am getting only a pulse at d o/p pin of tsop instead of a continuous active low signal:!:
pls help :cry:
if anyone cud tell me what i can do to remedy that or if anyone has a circuit that he/she has tested already it would be of gr8 help
thanks in advance
Re: IR distance sensors
alvarorahul said:
hi guys n gals
TSOP1738 works in burst mode. If your transmiter send a continous 38kHz signal, the signal is supressed by TSOP1738 circuitry. In this case, only a pulse will be generated.
In data sheet (www.vishay.com/docs/82030/82030.pdf) all suitable data format are described on page 3.
IR distance sensors
hey thanks cristianp & IanP that was of gr8 help
@IanP
i would like to know what is d approx. cost of d distance sensor that u mentioned ?
also can anyone tell me where i can get it in india????
I don't know where to get it in India - mabe you can contact SHARP-India ..
Anyhow, here is a couple of references incluing prices:
http://www.junun.org/MarkIII/Info.jsp?item=30
Regards,
IanP
IR distance sensors
hey IanP
do u have any distance sensors in a lower price range??? my budget is not that high
instead of tsops use ir tx /rx pairs which r very common.u can use in top down mode or side seeing type.if using side seeing fashion, calibrate the values given by d ADC to ur logic n use it to detect walls .
y don't u use an ultrasoinc distance measurment its easy and cheap.
please check
IR distance sensors
Thank for your Link. That I need
