How to test a fully differential opamp?
spbhu
Hi all, I am building a fully differential op amp for a low pass filter? How to make a testing bench under cadence simulation tool? Thanks very much.
Please refer to the following post:
There is attached a document provided by Cadence. I think you can use it as a reference for your testbench.
Regards.
Here's a presentation from Cadence about diff opamp charactorization for your reference
I am just need these materials too.
Thanks a lot , skal81 and analog99.
