zhi_yi
Full Member level 4
Hi there, please help me
i intended to make a 4x4 hex decoder using at89s2051, after i made the program, i tried it on at89s52, and it's work, but when i tried to write the hex file into at89s2051 and tried it on the circuit, it didn't work, i use asm language, i've changed the header into $MOD2051, the result is still some error occured, while i press button 0 until 7, it's work, but from 8 to F the errors occured. please help me.
any helps are very appreciated.
thank you
thank you
