Solar Tracking System
SHB
Newbie level 6
Newbie level 6
Islamabad/Pakistan
I Need design of solar tracking sys using microcontroller/ pc interface. the sys req to track sun from dawn to dusk to maximum use of solar energy.
Look in the elektuur 2006 July/Aug edition. www.elektuur.nl a super simple circuit does not use microcontroller only a motor and some sensors.
Paul.
Hi, I will post the elektuur schematic when I get home :)..
Paul.
Hi...
Very simple design...
Two LDRs (Light Dependent Resistors) in a wheatston balanced configuration...placed under an opaque sheild....placed very close to the LDRs...
When placed in light/sun...one of the LDRs exposed and unbalances the bridge...
the unbalanced bridge output picked up by ADC given to microcontroller for driving the motor...
MUST CONSULT SENIORs... :wink:
the best way is to read the voltage by adc and control motor depends on value.
There is a lot of links for solar, with couple of simple sun-tracking projects:
Also very interesting link for ebook about homemade solar sells:
Enjoy
    SHB
