sharas
Member level 4
I want to run a test on my chip, and make sure that the IP I bought is integrated according to the vendor's specifications.
I added checks for each pin according to the behaviour it should have: i.e., check that the pin has a constant value of 1, or check if the pin gets a value of Z or X during the simulation, or check that a pin that shouldn't, doesn't toggle during the simulation.
Does anybody have another check that he/she thinks are worth adding?
Thanks in advance,
Sharas
Thanks in advance,
Sharas
