sanders
Member level 3
How to set the excitation of this antenna in HFSS 9.2 ? Its radiating element are two triangular patches which is fed at the tips, a finite ground plane is under the substrate. Which kind of port is to use ? Wave port or lumped port ? and how to construct the structure of the feed, such as coax table or some other thing . Any help or advice will be appreciated!
Best regards!
Best regards!
