8051 reads 7-bit - possible?
DrWhoF
Advanced Member level 1
How to make 8051 microcontroller read a device with the following serial port setup:
Speed: 2400bps
Parity: EVEN
Bit Length: 7
Stop Bit: 1
Is it possible?
DrWho
Yes, just use the 8-bit mode and then handle the parity bit in your code.
Here you will find an example:
    DrWhoF
hai
actually the 8th bit is the parity
which you can remove easly
and the rest is the actual data
just take the data to accumulator
clear the D7
that's all
sun
    DrWhoF
Try this short code with Hyperterminal (2400,7, E, 1) ..
$NOPAGING
$MOD252
	ORG	 	0000H
	MOV 		TMOD, #20h
	MOV 		SCON, #52h
	MOV		PCON, #80h
	MOV 		TH1, #0E8h		; 2400bps & SMOD=1
	MOV 		TCON, #40h		; SETB TR1
	MOV 		50h, #'H'
	MOV 		51h, #'E'
	MOV 		52h, #'L'
	MOV 		53h, #'L'
	MOV 		54h, #'O'
	MOV 		55h, #10d		; LF
	MOV 		56h, #13d		; CR
;Main Program
SERIAL:
	LCALL 	Char_Get
	CPL		P1.0
	LCALL		Ser_Out
	LCALL 	Char_Sent
	SJMP		SERIAL
;Character sent subroutine
Char_Sent:
	MOV		R0, #07h		; Loop counter ..
	MOV		R1, #50h
S_Loop:
	MOV 		A, @R1
	LCALL		Ser_Out
	INC		R1
	DJNZ		R0, S_Loop
	RET
Ser_Out:
	JNB		TI, $
	CLR		TI
	MOV		SBUF, A
	RET
;Character receive subroutine
Char_Get:
	JNB 		RI, char_get
	CLR		RI
	MOV 		A, SBUF
	CLR		ACC.7
	RET
	END
When you press any key it sends this key + HELLO ..
If it works well you can use the same UART setup in your code ..
Regards,
IanP
    DrWhoF
