What is GLUE LOGIC in FPGA?
rakesh_aadhimoolam
Full Member level 4
Full Member level 4
while i started studying FPGA i met with one word GLUE LOGIC .................
what does it mean................
thank you and please help me understand the topic in detail..........
Re: what is GLUE LOGIC?
From Wikipedia:
In electronics, glue logic refers to the custom electronic circuitry needed to ensure compatibility for interfacing off-the-shelf semiconductor components. This is often achieved with the use af a CPLD or FPGA.
Regards,
Salam.
Ahmed M. Ragab
It's a simple logic circuit that is used to connect complex logic circuits together. For ex. an ASIC chip may contain large functions, such as a microprocessor and memory which are tied together via small amounts of glue logic
HEF4XXX like HEF4000
CD4XXX like CD4000
74HCTXXXX like 74HCT74
74HCXXXX like 74HC4000
Paul.
Glue logic is the logic required to interface circuit modules. The modules are typically complex chips such as microcontrollers, RAM, and peripheral ICs (for example, ADCs).
