inverter control using microcontroller
hamoksha
Newbie level 6
Newbie level 6
Egypt
microcontroller inverter
hi all,
i want to know how can the microcontroller is used to control an inverter.please give me any recommendations about this subject.
regards,
inverter using microcontroller
e.g. **broken link removed**
    hamoksha
usage of dsp in inverter
For inverter control u can use DSP for effective realtime operation..
dsp for inverter
hamoksha said:
hi all,
regards,
PIC16F72 is very much suitable for making an inverter
It has to perform following tasks
Genetare complementary pwm singnals ( Push pull configuration)
TO generate pwm use TIMER2 and use PR2 TO vary the pulse width
Analog inputs are
1) Mains sense signal
use stepdown transformer and scale to 0-5v level
2) Inverer o/p voltage signal
3) Battery voltage sense signal
Use resitor network and scale it ot 0-5v level
4) Relays and driver to for change over from mains to inv mode and vice-versa
5) Suitable leds for status indication
    hamoksha
    V
microcontroller, inverter
What is the use of DSP in inverter. Any idea?
Hi
1) May be for speed of operation
2) Used mainly in ONline UPS ( for sine wave o/p)
3) Multiple DC-DC conversion
4) Most of the DSPs have builtin multiple PWM o/p modules(Dspic)
1) can be configured for driving pushpull
2) or H-bridge driving
5) Programmable dead band options is present in Dspic
Also
6) Algorithms lik PID can be easily be implemented
Refer to Triple conversion Online UPS application note from TI site
Any url for DSP based controller..
    hamoksha
