Determining input impedance of CMOS in ADS
STOIKOV
Full Member level 4
Full Member level 4
is it possible to determine the input impedance of a cmos circuit in ADS by knowing the s11 or with other procedure ? for example in an amplifier or mixer.
Re: Input impedance
yeah for sure
u can in ads in sparameter simulation check the impedance claculation
u can fined the input impedance
khouly
    STOIKOV
Re: Input impedance
which steps should I follow ? work with an equation or with the help of some kind of plot ? regards
Re: Input impedance
it is easy in ads, ADD THE ZIN COMPONENT and do the simulation then you get the zin in the simulation result, thanks
    STOIKOV
Re: Input impedance
I'm sorry I cannot find that component, which pallet is it located ? I have 2003 version
Re: Input impedance
Hi
You should find it under "Simulation-S_Param".
    STOIKOV
Re: Input impedance
Stop using canned programs as a crutch!
If you already know S11, from a measurement or a simulation, then you already know the input impedance since S11=(ZL-Z0)/(ZL+Z0).
    STOIKOV
Input impedance
In smith option menu, change from "normalized" to 50 Ohm ( or other char. imp.) to see input impedance.
    STOIKOV
Re: Input impedance
in ADS uder S-parameters there is option to Zin component,,it will help you to determine the Zin, or you can select the Z-parameters from S-parameters simulator.....
    STOIKOV
