Help
Advanced Member level 2
Anyone can help me how to control a DC signal?
1) How can i use AC voltage as input signal to control the DC output signal?
When input 230VAC then DC output is High!
When input 0VAC then DC output is Low!
or
When input 230VAC then DC output is Low!
When input 0VAC then DC output is High!
Bellow is the simple design but since 230VAC is SINwave then the DC output will be alway Hi Lo signal. How can i control it?
2) If let say my JP24 pin2 connected AC Load. Is it posible? I try it on practical it doesn't work! Please help.
Thank You.
or
Thank You.
