Ideas for DSP oriented projects
konarkk
Full Member level 2
Full Member level 2
Mumbai , India
hi, I want to undertake my final year project on dsp .
so give me an idea or sites for same
studying in ECC ENGG.
project of voice detection by filtering
hi i am adnan student of telecommunication eng. i think you can work on fft algorithms or PLC .if ur interested in the the image processing ur can work on linear predective coding and invent the new methods for removing the noise
dsp project germany
Hello friends, i also want to do my senior year project in DSP. I am doing BSc Computer Engineering. Has any body worked on FPGAs and VLSI implementation of DSP algorithms. Can i get some good ideas on these lines.
that will be of great help to me.
    V
dsp kit base tellecommunication projects
Here are some ideas from my side: (I've done a project on Texas Instrument's C6711 based DSP Starter Kit TMS320C6711 DSK and currently working on my very own Spartan 3 1000k gates FPGA 8) )
1. VOICE SCRAMBLER
With voice as input, the o/p can be unscrambled voice (based on the user switch settings) The user switches are used to determine whether or not to up-sample.
2. PHASE LOCKED LOOP
software based linear phase locked loop
3. Adaptive Temporal Attenuator
suppresses undesired narrowband signals to achieve a maximum signal-to-interference ratio.
4. IMAGE PROCESSING
a. edge detection : for enhancing edges in an image using Sobe's edge detection
b. Median filtering : nonlinear filter to remove noise spikes in an image
c. Histogram Equalization : to make use of image spectrum
d. Unsharp masking : spatial filter to sharpen image
e: Point detection: for emphasizing single-point feature in image
5. FILTER DESIGN
6. FSK MODEM ( i did this)
7. u-LAW FOR SPEECH COMPANDING
8. VOICE DETECTION AND REVERSE PLAYBACK
9. ACOUSTIC DIRECTION TRACKER
10. MULTIRATE FILTER
11. PID CONTROLLER
12. VIDEO LINE RATE ANALYSIS
dsp project voice detection reverse playback
1. VOICE SCRAMBLER
hi.. im interested on this one...can you send me all docu on it??
pls/...
leoren_tm@yahoo.com...my emailadd...
ill be waiting for your help thanks in advance
Added after 1 minutes:
and also on number 8..
implementation of dsp in smile detection
For making projects in DSP, you can also refer to TI site, www.ti.com
In the knowledge base of this, you will find many gud application notes.These notes, takes up any one problem, discuss it & provides solution to it.Also, some appnotes also have source code attached with them. MOreover, they uses TI CCS(Code Composer Studio), which is available for free download (evaluation version, 30 days) from TI site.
what are good ideas for dsp projects
hi... also lukin for mine... mine is about audio and electro-acoustics DSP.... pls help... thnx..:)
Re: DSP PROJECT
refer to project reference posted by u"audio and electro-acoustics DSP".
ould u help me for same
Re: DSP PROJECT
pardon me, refer to where? iv tryd serchin for my posts and found nothin about audio and electro acoustics project... tnx..:) im also lookin for an idea though..:)
DSP PROJECT
this is a ncie project.
voice recognition using dsp kit
Added after 9 seconds:
this is a nice project.
DSP PROJECT
any one give the links of the projects
Re: DSP PROJECT
You can try to interface C6713 with a CMOS camera in order to use it as webcam!!!
Re: DSP PROJECT
Now i have select the project on DSP it is DSP based text to speech converter, but now i m getting confusion about database , can any one help in this context
Re: DSP PROJECT
I have come up with some ideas.
- watermarking in MP3s
- communications projects building FM, AM or DSSS systems.
- audio equilizer
regards
DSP PROJECT
Hi
I give you this book .
thanks
Please send to me your mail and i will send to u books on DSP.
Re: DSP PROJECT
YOU SHOULD BE DOING THE PROJECT OF:
REAL TIME IMPLEMENTATION OF ADAPTIVE MULTIRATE (AMR) SPEECH CODEC ON TMS320C5416.
I M ALSO DOING MY PROJECT IN THIS FIELD, I THINK ANY PROBLEM REGARDING THE PROJECT CAN BE DISSCUSSED, IT WOULD BE BEBEFICIAL FOR BOTH OF US. ITS UPTO YOU, WHAT U WANT.
Re: DSP PROJECT
GOod project reading
Re: DSP PROJECT
i guess you might go to deinterlacing field ......it wide and promising one
Re: DSP PROJECT
hi all
i want information a bout implementation FIR filter using dsk kit tms320c6xx
