esojam
Newbie level 5
ludwig polarization
Hello. I've got a problem. I need to design a dielectric slab in a conical horn antenna for cicular polarization. I use CST, but I don't know how to see the result. How can I see in CST if the polarizator works? Axial ratio must be "1" for circular polarization, but there is only result in "negative" numbers. Which other quantities i have to see for result? The magnitude of the electric field in the probe, which is oriented in X-axis is about 50dB lower then in probe, which is oriented in Y-axis = so it's good and it's truth (basic mode TE11) - it's without dielectric slab. But with the dielectric slab, the magnitude will change only a little.
So, does anybody help me? Thanks
