[C] What's pointers like *** mean?
davyzhu
Advanced Member level 1
oriental
triple dereference
Hi all,
I am reading a reference software of H.264 video encoder (http://iphome.hhi.de/suehring/tml/download/).
And I found a lot of variable are declared like below:
imgpel **imgY = p->imgY;
imgpel ***imgUV = p->imgUV;
There are even six pointers ******.
What's pointers like *** mean? Is it pointer to a structure and so on?
How can I know where does the pointer point to?
And why use this style, is it convenient?
Best regards,
Davy
The dereference operator (*) allows you to access the data that the pointer is pointing to.
E.g.
pPointer = 0; // sets the pointer to zero.
*pPointer = 0; // sets the memory pointed to by pPointer to zero.
Sometimes its necessary and convenient to double or triple dereference pointers to access data in structures or arrays. I have a queuing system in C that uses arrays of pointers. Each pointer, points to a structure. Now to access the queue I use a Head and Tail pointer. Accessing the data in the queue can be done through the use of a double dereference pointer.
E.g.
*pTail // Points to the memory address in the queue.
**pTail->access structure on heap // Points to the data at the memory address in the queue.
Hope that helps :)
    davyzhu
hi ,may be multi dimentional arrays!
    davyzhu
You can have a pointer to a pointer, or a pointer to a pointer to a pointer ect, ect. If you take notice of misra rules, they advise that you should not use more than 2 levels of indirection as it then becomes difficult to understand the code.
    davyzhu
