Mains Line voltage detection
ZeleC
Full Member level 5
Full Member level 5
Hi
I want to build a small interface circuit that detects the presence of a the mains 230V AC,I want to feed the signal to a uC (0 =no line voltage, 1 line voltage present)
I have a couple of ideas just want to c yours
thanks
You can use the attached circuit:
ZeleC said:
Hi
thanks
if you need galvanic isolation you could use this circuit.
stefano
it seems that these circuits will give a square wave image of the AC line ??
well Im looking for a logic 1 for presence and logic 0 absence.
ZeleC - the possibitlies are infinite (c) :
Put another capacitor parallel to R3 in second schematics, increase R3 value and and choose newly inserted capacitor value as R3 (Ohm) * Cnew (Farad) = Seconds delay before mains disappeared (rough estimation ).
ZeleC,
output of stefano.delfiore's circuit isnt square wave!
if you check optocoupler you see that it use 2 LED and each LED light in one half cycle.
I think you can use this circuit.
if any pulse appeared in output, increase C1 value to 1uF or 2.2uF.
Regards,
Davood.
Davood Amerion said:
ZeleC,
Regards,
Davood.
to whom it may interest, I acquired by oscilloscope some waveforms from the circuit that I have posted.
stefano
