Diode/rectifier for cancelling negative unipolar voltage
watertreader
Full Member level 3
Full Member level 3
Unipolar boltage
Just for verification
If I need to deliver a unipolar voltage(+ve voltage) to a device but my source is a square wave, can I use a diode/rectifier to cancel out the negative voltage? What other things do I need to watch out for(beside the breakdown)?
Thanks for your help!
Re: Unipolar boltage
One single diode may do ..
But you may consider adding a filter/smoothing capacitor to make the control signal more "DC" and a zener diode to limit the maximum voltage (if required) ..
Regards,
IanP
watch that the negative voltage doesn't exceed the breakdown voltage in the negative cycle by zener...but the final voltage will be the voltage u input minus the diode voltage and that across any resistor you put....so don't forget to put that in mind when calculating the final voltage
Salma:D
