vfurlan
Full Member level 2
Boundaries overlap
Hi
I have an interesting problem (for me atleast)!
I found HFSS tutorial describeing an coax fed patch antenna together with .hfss file for the same antenna (patch_antenna(2).hfss). This file works perfectly!
Now, a made an IDENTICAL file for the IDENTICAL antenna (patch_antenna(1).hfss) using the tutorial (practically copying it) and IT DOESN'T WORK!!! It sais that boundaries rad1 and perfE2 overlap (which is correct) and it won't solve it.
Can you please take a look at patch_antenna(2).hfss and tell me why in this file boundarise don't overlap!
Hi
